Guest andycab Posted July 22, 2010 Share Posted July 22, 2010 got a mk5 escort si just got motor and struts now my car has a window switch next to hand break is this also the roof switch? is there a place i can just plug my motor in to? help needed asap Quote Link to comment Share on other sites More sharing options...
Guest Lee81 Posted July 22, 2010 Share Posted July 22, 2010 Not sure on location of roof switch on mk5 but would assume thats where it would be. You need the switch first. Then make up loom with two switched double pole relays. You can get the live for the switch from the power window circuit. Then through the switch to the relay. Do this twice because you should have a hood up and hood down switch. There used to be a diagram on here for the mk4 which is the same circuit you need to form. You then need to get a live supply to the relay that will power the power roof motor. Needs to be 30amp. There may be a supply line in place already. You would need to look at a car with power roof or hanynes manaul and trace wires back. Alternativly you could use the supply from the rear heated screen as it would be rare that these would both be in use at the same time. Quote Link to comment Share on other sites More sharing options...
Guest andycab Posted July 22, 2010 Share Posted July 22, 2010 where do you get relays from and how much? Quote Link to comment Share on other sites More sharing options...
Guest Feeble Posted July 22, 2010 Share Posted July 22, 2010 I think there's a whole wiring harness you need... Quote Link to comment Share on other sites More sharing options...
Guest Cabbytech Posted July 22, 2010 Share Posted July 22, 2010 I think there's a whole wiring harness you need... I agree, you would be best getting a proper loom for the electric roof, i dont think you will find the roof circuit in the haynes manual, because its not in mine, the switches in front of your handbrake are for the elec windows and one to the side of the handbrake would be for the electric roof. Quote Link to comment Share on other sites More sharing options...
Guest andycab Posted July 24, 2010 Share Posted July 24, 2010 iv got a switch next to my handbreak that sends all the windows down and up, it looks like the 4 oval window switches that are in font of my handbreak what i want to know is did ford put a loom in all the cabbys? if so where is the end of this loom ? Quote Link to comment Share on other sites More sharing options...
Guest Feeble Posted July 25, 2010 Share Posted July 25, 2010 I'm gonna say no... Quote Link to comment Share on other sites More sharing options...
Guest andycab Posted July 25, 2010 Share Posted July 25, 2010 lol cheers mate ill start puttin in new loom need relays tho and a switch grrrr Quote Link to comment Share on other sites More sharing options...
Guest Feeble Posted July 25, 2010 Share Posted July 25, 2010 I'm pretty sure my Mk5 XR3i never had the loom, so that's what I'm going off... I don't think Ford were as lazy back then either... Quote Link to comment Share on other sites More sharing options...
Guest dodgy01 Posted July 26, 2010 Share Posted July 26, 2010 I'm pretty sure my Mk5 XR3i never had the loom, so that's what I'm going off... I don't think Ford were as lazy back then either... how many wires does the pump have going to it i cant belive that it is any more than relays to alter the pos and neg feeds over ,as far as i am aware there are no pressure sensors or limit switches envolved But i could be wrong the amount of wires going to the pump will help Quote Link to comment Share on other sites More sharing options...
Guest Lee81 Posted July 26, 2010 Share Posted July 26, 2010 Pump has a silver cicuit cut out on it that cuts supply if current gets to high. Relays are from any motor accessory place. I will check mine to get the ring code for them. Quote Link to comment Share on other sites More sharing options...
