Guest Myers820 Posted July 12, 2010 Share Posted July 12, 2010 Hi guys, new to this forum. but i am now a mk3 cab owner. Bought it as a rolling shell as a project. i have a mk4 car for a donor using dash and carpet etc. Looking at gearbox mouting there does not seem anyway i can fit :S. i was planning dropping engine, box and shafts out the bottom and bolting it rite into my mk3, is that possible ? any hints or tips ? or will it just not fit ? Quote Link to comment Share on other sites More sharing options...
Guest dazzersrst Posted July 12, 2010 Share Posted July 12, 2010 you can do it ive done loads of engine changes Quote Link to comment Share on other sites More sharing options...
Guest Myers820 Posted July 12, 2010 Share Posted July 12, 2010 (edited) ok sweet, will the box mount be a problem? or can i just drill and bolt the cross gearbox engine mount ? Edited July 12, 2010 by Myers820 Quote Link to comment Share on other sites More sharing options...
Guest dazzersrst Posted July 12, 2010 Share Posted July 12, 2010 all the holes should be there mate should just fit in i put a efi engine out of a fiesta in my mk3 cabby Quote Link to comment Share on other sites More sharing options...
Guest Myers820 Posted July 12, 2010 Share Posted July 12, 2010 i know what your saying but the gearbox mounts are different on the mk3 to the mk4, mk4 has a large bar mout accross the bottom on it, were as the mk3 has a front mounted gearbox. the mk4 has holes for the larger mount but the mk3 does not :S Quote Link to comment Share on other sites More sharing options...
Guest dazzersrst Posted July 12, 2010 Share Posted July 12, 2010 use the mk3 one on the mk4 box and the mk3 mounts you just need to play around with the parts you have Quote Link to comment Share on other sites More sharing options...
Guest Myers820 Posted July 12, 2010 Share Posted July 12, 2010 cool cheers for your help Quote Link to comment Share on other sites More sharing options...
