Guest anton1 Posted July 1, 2010 Share Posted July 1, 2010 Hello everyone. Can you change the oil pump with engine still in car and is it difficult? Any tips to make it easier? Thanks! Quote Link to comment Share on other sites More sharing options...
Guest Lee81 Posted July 1, 2010 Share Posted July 1, 2010 Yes you can. Assuming its cvh. Slacken tensioner bolts. Remove the cambelt. Then its just a case of removing the bottom pulley and gear wheel which slides off once the nut is undone. Remove the pump bolts and it will slide off over the end of the crank. Make sure you clean the block up good where the seal fits and be careful not to get any debris in the oil ways Quote Link to comment Share on other sites More sharing options...
Guest anton1 Posted July 2, 2010 Share Posted July 2, 2010 Thanks mate I will give it a try. Also will I need to replace the seal/gasket with a new one? I'm changing it because the top end is noisy and I think it may be oil starvation? Quote Link to comment Share on other sites More sharing options...
Guest shaun Posted July 2, 2010 Share Posted July 2, 2010 might find the pick pipe or strainer my be blocking up.these are in the sump... Quote Link to comment Share on other sites More sharing options...
