Guest tommyc1 Posted June 20, 2010 Share Posted June 20, 2010 just had engine rebiult on my mark4 cab but got niosy tappets i heard differant oil might help does anyone now Quote Link to comment Share on other sites More sharing options...
RobMk4TwinCarb Posted June 20, 2010 Share Posted June 20, 2010 10/40 is the right oil for a standard engine I believe, also I have read that unless you change both the cam and the tappets then it will be noisy again in no time. Quote Link to comment Share on other sites More sharing options...
Guest Lee81 Posted June 21, 2010 Share Posted June 21, 2010 First find out what was replaced at the time of the engine build if possible. Not all companies bother to replace them. As said before they are best replaced with the cam or at least a check of the cam for shape and regrind. Failing this its possible something else has had a knock on effect of this i.e. head gasket or themstat not working. I would suggest the best oil would be 15w 50 Silkolene Pro R by. The CVH engines really run well on this and use next to no oil. Quote Link to comment Share on other sites More sharing options...
Guest tommyc1 Posted June 21, 2010 Share Posted June 21, 2010 First find out what was replaced at the time of the engine build if possible. Not all companies bother to replace them. As said before they are best replaced with the cam or at least a check of the cam for shape and regrind. Failing this its possible something else has had a knock on effect of this i.e. head gasket or themstat not working. I would suggest the best oil would be 15w 50 Silkolene Pro R by. The CVH engines really run well on this and use next to no oil. thanks for the advice mate it definately had new pipper cam and followers i will try that oil though and see how i get on Quote Link to comment Share on other sites More sharing options...
Guest Cabbytech Posted June 29, 2010 Share Posted June 29, 2010 I agree with the above, check if new cam and followers were fitted, new followers on an old cam is asking for trouble, also if the brass lubrication bushes that lubricate the cam are blocked up, this would cause cam probs. When replacing cam/followers i usually take the head to a rebuild specialist near me to have it chemically cleaned and checked over before i put it back together again. Quote Link to comment Share on other sites More sharing options...
