Guest gazb1409 Posted June 14, 2010 Share Posted June 14, 2010 hi could anyone help my mk6/7 cabby as started to pull to the right as i accelerate and but the steering wheel does not move and i cannot find the problem i have replaced the driveshafts, wishbones, gearbox mounts, i am 99% sure its not the diff as i tried to wheelspin it and both front wheels spun i also changed the tyres and wheels with no success i am now out of ideas as to what this could be any input would be greatly appreciated thanks Quote Link to comment Share on other sites More sharing options...
Guest Cabbytech Posted June 14, 2010 Share Posted June 14, 2010 Check your wishbone mounting rubbers again and did you have the tracking done when you changed the wishbones ? Quote Link to comment Share on other sites More sharing options...
Guest gazb1409 Posted June 15, 2010 Share Posted June 15, 2010 hi i checked the wishbones and the tracking is spot on 2 Quote Link to comment Share on other sites More sharing options...
Guest shaun Posted June 15, 2010 Share Posted June 15, 2010 as cabbie said would say rear wishbone bushes as weak common problem on mk5/6.....how long ago did you fit them? most fit ploy bushes in the wishbones to stop this take wishbone off and look at the rubber's any splitting then they need changing my mk6 si estate use to go through them quite quick....sure they were cheap copy's hope this helps Quote Link to comment Share on other sites More sharing options...
Guest mossop1 Posted June 15, 2010 Share Posted June 15, 2010 I had this at work cheap coppies are cr@p lol now only fit ford ones now unles otherwise told by customer Quote Link to comment Share on other sites More sharing options...
Guest gazb1409 Posted June 16, 2010 Share Posted June 16, 2010 ahhh thanks i assumed becouse of the verring it would be the front wishbones i wil change the rear ones and let you know what happens many thanks for your help Quote Link to comment Share on other sites More sharing options...
