Guest s6boy1979 Posted June 7, 2010 Share Posted June 7, 2010 I have had an idling prob for a while, it has ticked over lumpy for a while so started replacing bits, replaced the idle control vale, no change, MAP sensor, plugs, leads, air and fuel filters, still the same. Someone has mentioned it could be the crank position sensor and someone else mentioned the air charge temp sensor. I unpluged the act sensor and it ticked over ok and as soon as i plugged it back in it goes all lumpy again. So as they are £40 a throw i thought i would swap it for another off another car that was ticking over fine and i still got the same thing, pulgged in it idles lumpy but unplugged it is ok. So i put them on a multi meter and they tested ok so i am a little confused!!! Could it be a comdination of a few things or is it def the act sensor????? Quote Link to comment Share on other sites More sharing options...
Guest Cabbytech Posted June 29, 2010 Share Posted June 29, 2010 Have you checked the vacuum hoses, i had a similar prob on my mk5 cab and it was a hole in a vac pipe that ran round the left side of the engine bay and down to an air receiver box inside the wing, once repaired the lumpy tickover went away. Quote Link to comment Share on other sites More sharing options...
Guest s6boy1979 Posted June 29, 2010 Share Posted June 29, 2010 I will have a look to see if i can find any, but i def know it's not the act sensor as replaced it and no change. Quote Link to comment Share on other sites More sharing options...
Guest s6boy1979 Posted June 29, 2010 Share Posted June 29, 2010 Ok def not an air leak, checked all hose's 3 times!!! Must be the crank sensor, it's got to be Quote Link to comment Share on other sites More sharing options...
Guest Cabbytech Posted June 30, 2010 Share Posted June 30, 2010 Lets hope your right, good luck with it, let us know how you get on. Quote Link to comment Share on other sites More sharing options...
Guest s6boy1979 Posted June 30, 2010 Share Posted June 30, 2010 Will do Quote Link to comment Share on other sites More sharing options...
Guest s6boy1979 Posted July 6, 2010 Share Posted July 6, 2010 I am at a total loss now as changed the crank sensor and no change!!!!!!! If i unplug the air temp sensor it idles better but just runs poor so could this be the ECU? Any help would be great as i am so stuck now Quote Link to comment Share on other sites More sharing options...
Guest s6boy1979 Posted August 3, 2010 Share Posted August 3, 2010 Turned out to be a combination of the fuel pump on it's way out and the mixer adjuster not working, so just a case of getting the mixture adjusted as running a bit rich and it will be sorted. Quote Link to comment Share on other sites More sharing options...
