Guest cuddles Posted June 2, 2010 Share Posted June 2, 2010 Hi i need to replace the wishbones on my mk5 cabbie could anyone give some tips on what and where to buy etc also ive been told to use the old wishbones but replace the bushes with stronger ones is this possible and how do i go about it? thanks Quote Link to comment Share on other sites More sharing options...
Guest Lee81 Posted June 2, 2010 Share Posted June 2, 2010 You can replace them but you will need a 10 ton press or similar to push them out. They can be burnt and cut out but its not the best way. Unless you buy aftermarket ones such as proflex or similar you will need a press to install the new ford ones. Your better off replacing the wishbones anyway. I use ones made by QT ( Quinticensial - Not sure of spelling ) They are far stronger, more accurate and the bushes outlast the ford ones by along way. They were about £55 a pair trade last time i bought them. Quote Link to comment Share on other sites More sharing options...
