Guest GIZMO Posted May 31, 2010 Share Posted May 31, 2010 well hello people i have a problem hence why im ear,anyway on my mk4 scort efi (1990) it keeps blowing oil out da air filter,and not jus a lil bit either,im finking it could do wiv the fact dat the previuse owner put on a k n filter and adapted the two other pipes to the k and n as well,the oil it self is coming out the rocker breather threw the filter at the back and den coming out the k and n,and covering the whole left side of the engine bay every time i go out,unless i run her on low oil wich i ovisly dont want to,anyway enuff of me dribbling on,can anybody help Quote Link to comment Share on other sites More sharing options...
Guest Lee81 Posted May 31, 2010 Share Posted May 31, 2010 Some pics would be best to see what has been done. Check all breather pipes for blockages and also check one way valves and foam elements that may be in place in the hoses. The foam can break down. What mileage has the engine done?. I know on the MFI ones when the engine starts to breath heavy from wear it will fill the air filter housing up with oil. Quote Link to comment Share on other sites More sharing options...
Guest georgeking Posted May 31, 2010 Share Posted May 31, 2010 hi go on ebay and buy a oil catch tank and take it off the air filter or take it out and put a small k&n type on as the oil is being sucked out when you put your foot down you will have oil smoke when driving from tale pipe Quote Link to comment Share on other sites More sharing options...
Guest steelcabby Posted June 1, 2010 Share Posted June 1, 2010 as said check all the main breather pipes around the engine for blockages. it will only take a slight blockage to cause big pressure. also when was the oil change last. if its never been changed it could be going sludgy causing pressure. either way its not good and will detroy your engine Quote Link to comment Share on other sites More sharing options...
