Guest calum89 Posted May 24, 2010 Share Posted May 24, 2010 my mk4 EFI cannot idle when it is hot, it will rev from around 700rpm to 1400rpm and sometimes cut out. Also when driving at a steady speed when its hot it will rev on its own causing the car to surge forward. I have tried cleaning the idle control valve but it has not made any difference and checked all the hoses that are part of the inlet manifold but theres nothing obvious that could be causing the problem. Anyone able to give me an idea whats wrong? Quote Link to comment Share on other sites More sharing options...
Guest georgeking Posted May 25, 2010 Share Posted May 25, 2010 my mk4 EFI cannot idle when it is hot, it will rev from around 700rpm to 1400rpm and sometimes cut out. Also when driving at a steady speed when its hot it will rev on its own causing the car to surge forward. I have tried cleaning the idle control valve but it has not made any difference and checked all the hoses that are part of the inlet manifold but theres nothing obvious that could be causing the problem. Anyone able to give me an idea whats wrong? have you chequed the fuel pump is working at 3 bar to fuel lines as if its up and down it will do the same thing Quote Link to comment Share on other sites More sharing options...
Guest calum89 Posted May 27, 2010 Share Posted May 27, 2010 nope not checked the pressure from the fuel pump, al try that thanks Quote Link to comment Share on other sites More sharing options...
Guest shaun Posted May 27, 2010 Share Posted May 27, 2010 if it gets worse when hot maybe air leak. But do know depends on what idle air control vavle you have cos Ford changed them to different 1's and mounted them in different place. Quote Link to comment Share on other sites More sharing options...
Guest calum89 Posted May 29, 2010 Share Posted May 29, 2010 yea runs fine when cold, problems start when it heats up. idle control valve is mounted onto the side of the inlet manifold with 4 bolts which i have had to tap to a bigger size as originals where stripped. Quote Link to comment Share on other sites More sharing options...
