Guest cuddles Posted May 11, 2010 Share Posted May 11, 2010 hi can anyone help i have a mk5 xr3i cab, iv had no problems with it untill now, when i tried to start it there was nothing there, it seemed like the starter motor but there is a ticking noise it last about 1 min then gos off but the car dont start. please can anyone help me. Quote Link to comment Share on other sites More sharing options...
Guest Cabbytech Posted May 11, 2010 Share Posted May 11, 2010 Hi, what does the little red led lamp next to the clock do when you try to start your car ? is it flashing so many times then stops, then does it again, if so let me know how many flashes it does between pauses and i will see if that may be your problem. Quote Link to comment Share on other sites More sharing options...
Guest cuddles Posted May 12, 2010 Share Posted May 12, 2010 hi, i did as you said, when i unlocked the car it starts ticking it sounds like the hazzards are on and the light next to the clock is on when the ticking stops the light starts flashing i tried counting then but gave up at 130 flashes while i was doing this the car door was open so i shut it and the ticking started again and the light went soild again untill the ticking stoped, same thing happens when i turn the ignition on or off and same thing when i lock and unlock the car. can you help. thanks hazel. Quote Link to comment Share on other sites More sharing options...
Guest Lee81 Posted May 12, 2010 Share Posted May 12, 2010 Sounds like the battery is flat. The relays are clicking on and off as they try to supply power to a circuit but theres not enough and they switch off themselves. Also the starter will make a clicking noise when there isn't enough power left in the battery. Try jump leads first to see if this makes a difference before checking relays and starter. Quote Link to comment Share on other sites More sharing options...
Guest Cabbytech Posted May 13, 2010 Share Posted May 13, 2010 Hi, try unlocking the car from the other door, sometimes the door latch for the factory immobiliser throws a wobbly and acts up, also check the alarm contact in the boot and on the bonnet to make sure they are working correctly. Let me know how you get on. Quote Link to comment Share on other sites More sharing options...
