Guest deanobeattie Posted May 2, 2010 Share Posted May 2, 2010 hi want to get better brakes on my 88 cabby what year cozzie calipers do i need to get hold of r they single piston and is it worth the expense would i see a diference thanks Quote Link to comment Share on other sites More sharing options...
RobMk4TwinCarb Posted May 2, 2010 Share Posted May 2, 2010 Sierra cossie 2wd calipers 4 pots and discs would be what your after I think. If you find one take the rears aswell as they go on pretty easily. Quote Link to comment Share on other sites More sharing options...
Guest deanobeattie Posted May 2, 2010 Share Posted May 2, 2010 what si thanks any info would be great thanksze i,m buying new 340mm cozzie or 240mm xr&rs do i need to go higher with the 340mm Quote Link to comment Share on other sites More sharing options...
Guest deanobeattie Posted May 2, 2010 Share Posted May 2, 2010 (edited) sorry cozz283mmx24 or the rs 260mmx24.3mm would i get away with the larger ones thanks Edited May 2, 2010 by deanobeattie Quote Link to comment Share on other sites More sharing options...
