Guest ajaydohc Posted April 15, 2010 Share Posted April 15, 2010 theres this loose wire and its wreckening my head can anyone tell me wat it does or where it goes thanks its the brown and white wire in the pic Quote Link to comment Share on other sites More sharing options...
Guest s11pyk Posted April 15, 2010 Share Posted April 15, 2010 he connector looks like the one for the temp sender thingy (technical term!) on the front right of the block. or maybe the reverse light switch? Quote Link to comment Share on other sites More sharing options...
Guest dazzy16 Posted April 15, 2010 Share Posted April 15, 2010 Id say its defo the temp sender wire as its coming from the fan loom? Quote Link to comment Share on other sites More sharing options...
Guest s6boy1979 Posted April 15, 2010 Share Posted April 15, 2010 It's def the temp sender wire, the sender is in the front of the head, as you look at the engine right hand side, right next to the exhaust mainifold. Quote Link to comment Share on other sites More sharing options...
Guest mossop1 Posted April 15, 2010 Share Posted April 15, 2010 it could be for f all on that car as ford tended to use that loom in a few versions of ford ie mondeo. Quote Link to comment Share on other sites More sharing options...
Guest Lee81 Posted April 15, 2010 Share Posted April 15, 2010 100% that is the temp sender wire for the gauge on the dash Quote Link to comment Share on other sites More sharing options...
Guest caffull Posted April 27, 2010 Share Posted April 27, 2010 dont no wat thats is but its not the temp sender wire, temp gauge is a twin wire plug on the top of the engine & the 1 in the pipe is for the fan, i dont have this on mine are you sure its a standard ford cable...............? Quote Link to comment Share on other sites More sharing options...
RobMk4TwinCarb Posted April 27, 2010 Share Posted April 27, 2010 It is exactly as the other guys have told you, the temp sender for your guages. It goes on a thread type thing on the front right of the head. Quote Link to comment Share on other sites More sharing options...
Guest waddinb Posted March 5, 2012 Share Posted March 5, 2012 Hi guys, can anyone be a bit more specific as to where this connects, I have the same problem and I can't see anything with threads on in that area other than the manifold studs. Cheers Quote Link to comment Share on other sites More sharing options...
