Guest xrcabriozetec Posted April 11, 2010 Share Posted April 11, 2010 hi i am new to this site so would be grateful of any help, i fitted a zetec engine to my 88 cabby but am having trouble with all the wiring to get it to turn over let alone getting it started, it has PATS on it which i was told could be a problem, so if anyone has any ides please let me know thanks Quote Link to comment Share on other sites More sharing options...
Guest charlie74 Posted April 12, 2010 Share Posted April 12, 2010 are you using the ecu for that engine and if so do you have all the pats system parts in place? ie ecu/transponder/key? Quote Link to comment Share on other sites More sharing options...
Guest xrcabriozetec Posted April 12, 2010 Share Posted April 12, 2010 are you using the ecu for that engine and if so do you have all the pats system parts in place? ie ecu/transponder/key? yes mate i have it all exactly as it came out of the si have the red key the part that goes around the ign barrel and ecu just not sure what wires to cut to wire it all in, there are so many it all looks abit confusing, thanks for the quick reply Quote Link to comment Share on other sites More sharing options...
Guest georgeking Posted April 25, 2010 Share Posted April 25, 2010 email me at gking8000@yahoo.co.uk and ill sent you the wirring diagram for the pats and if its been of car it will have lost codes and black box i can tell you how to sort it but not on here as it will get just about all cars nicked i have ford tis upto 2004 all cars Quote Link to comment Share on other sites More sharing options...
