Guest welshie Posted April 9, 2010 Share Posted April 9, 2010 can anyone tell me if number one cylinder injector is a primary unit on the efi as i've pinpointed my starting fault down to injectors .by power probing the live feed going to them and giving it several flicks it starts on the button otherwise you have to flick ignition on and off i think number 1 injector is sticking which is not allowing fuel to the rest of the rail but this theory only holds up if fuel has to get past 1st injector to feed the rest.once she is running theres no problems until you switch off and go to restart(cranking with no fuel) give them a zap with probe and away she go's again Quote Link to comment Share on other sites More sharing options...
Guest georgeking Posted April 25, 2010 Share Posted April 25, 2010 mate it will not stop fuel getting to the rest number 1 is cylinder has number one injector 9 times out of ten its your fuel pump mate. if you dont get 3 bar on turn of key then turning key more than once will give 3 bar start with new pump Quote Link to comment Share on other sites More sharing options...
