Guest mk4stu Posted April 8, 2010 Share Posted April 8, 2010 Mot is due next week, just checking over car and there is play in the steering rack n/s. Was wondering if there is any ajustment at all or is it a new rack needed? Cheers, stu Quote Link to comment Share on other sites More sharing options...
Guest welshie Posted April 9, 2010 Share Posted April 9, 2010 no mate no adjustment on the rack arms just replace with new Quote Link to comment Share on other sites More sharing options...
Guest mk4stu Posted April 9, 2010 Share Posted April 9, 2010 Give me back me mk4!! The mk6 is in bits, the only way I can see to get the steering rack out is to drop the subframe. Is there any other way?, everything is solid with rust wd40 won't budge it. Need it done as it's me daily drive and there is half an inch play in the rack Quote Link to comment Share on other sites More sharing options...
Guest shaun Posted April 11, 2010 Share Posted April 11, 2010 sure its the rack not track rod ends? you might get away with getting it out with out dropping sub frame through were track rod ends are with twisting and turning....hope you sort it with out to much hassle Quote Link to comment Share on other sites More sharing options...
Guest georgeking Posted April 25, 2010 Share Posted April 25, 2010 no sub out and it will be a truble from start Quote Link to comment Share on other sites More sharing options...
