Guest markini5 Posted March 4, 2010 Share Posted March 4, 2010 hi, need advise on efi loom, basically ive got a mk4 escort cab 87 plate with fiesta rs turbo 2.1 zvh conversion. ofab ecu brought the car with this conversion done, but since then fuel pump, starter motor and clocks intermitent, now fuel pump wont prime in, was controlled by imob that is now out as stoped working, but fuel pump still wont work fuel relay had been completely bypassed, so i want to start a fresh unless some one knows in detail how to lay a new loom for just fuel pump and relays and where all the wiring goes. or complete loom and what ford loom would be best suited to my car, fiesta efi or escort efi turbo loom or can you use xr3i/2i looms, i personally thought i might be able to use an escort xr3i efi loom, but would it run a turbo? if anyone is in the know or even be prepared to sort it for me id be happy to pay. im in ilkeston derbyshire. thanks Quote Link to comment Share on other sites More sharing options...
Guest bigjon Posted March 4, 2010 Share Posted March 4, 2010 u would be able to run an xr3i loom u may have to do a few pin changes depending on the ecu used hope this helps. Quote Link to comment Share on other sites More sharing options...
