Guest Uxb1979 Posted February 20, 2010 Share Posted February 20, 2010 hello can anyone please tell me if you can adjust a handbrake on a mk 5 cabby that has discs all round???? if so how? Quote Link to comment Share on other sites More sharing options...
Guest markeyboy Posted February 21, 2010 Share Posted February 21, 2010 the brakes on the rear (if they are the sandard correct ones) will have drum brakes on the inside of the discs. if it is the same as the mk6 there will be an adjustment at the hand brake leaver, if you pull the gater up you should see a stud with a nut on it. this is where you can adjust it from. if it has reached the end of its travel (most of them have) you may need to replace the cable which is also pretty stright foward Quote Link to comment Share on other sites More sharing options...
