Guest emmy Posted January 31, 2010 Share Posted January 31, 2010 Hi guys im Emmys husband Darren ,ive been trying to sort the wiring for the roof as it didnt work when i bought it for her last week but while tracing the loom back behind the dash i found the ignition feed (yellow wire)isnt connected to anything and ive spent ages trying to find where to plug it in,i ran a jumper cable from the yellow feed on the ign switch and the roof works perfectly ,i would prefer to get it connected into the loom correctly or will it be ok to just take a feed from the yellow ignition wire behind the steering cowl,ideas much appreciated Quote Link to comment Share on other sites More sharing options...
Guest smoothy582 Posted January 31, 2010 Share Posted January 31, 2010 hi darren that wire does connect to the acc(yellow) wire. there should be a plug there for it but if not you can just add one. rich Quote Link to comment Share on other sites More sharing options...
