Guest s6boy1979 Posted January 16, 2010 Share Posted January 16, 2010 My cab is using a lot of fuel and i mean an awful lot, the moddded 2.0 gti pug i have uses half what my cab does. I have changed the air filter, plugs(gapped correctly), fuel filter, leads, oil filter, oil, MAP sensor, idle control valve but still use way to much. I will be changing the cam belt tomorrow so will make sure it is timed up properly. Just wondered if anyone could have any ideas what else it could be! Cheers Quote Link to comment Share on other sites More sharing options...
