Guest shaggy Posted December 15, 2009 Share Posted December 15, 2009 i want to put a turbo engine in my mk3 cabby i have a complete engine and loom from a fiesta rst would i be able to use that or do i need one out of an escort? any help much apreciated Quote Link to comment Share on other sites More sharing options...
Guest shaun Posted December 16, 2009 Share Posted December 16, 2009 Hi mate loads have used the rst fiesta as long as you got ecu and fuel ecu you will have to get a fuel pump out of efi turbo aswell not sure what else you need but grin and bear it and post problems as you go some one will answer you probs hope this helps Quote Link to comment Share on other sites More sharing options...
Guest shaggy Posted December 16, 2009 Share Posted December 16, 2009 Hi mate loads have used the rst fiesta as long as you got ecu and fuel ecu you will have to get a fuel pump out of efi turbo aswell not sure what else you need but grin and bear it and post problems as you go some one will answer you probs hope this helps well i have the complete car as its my brothers and he putting cossie lump in his so i should be able to get nearly all the main parts from him its just the turbo that is bigger too Quote Link to comment Share on other sites More sharing options...
Guest steelcabby Posted December 17, 2009 Share Posted December 17, 2009 if yours is an xr3i injection mk3. you will be fine with what you got. tank and fuel pump will be fine if you have a carb xr3 cabby, your need fuel tank and returns, fuel pump and loom from an escort EFI. if you get an escort EFI loom it will make you life very easy. then all you have to do is plug the fezzy ecu in and swap acouple of wires over to get it running. well depending on weather you have ofab or ofac management from the fiesta?? Quote Link to comment Share on other sites More sharing options...
