Turbo My Mk3
Guest shaggy
i want to put a turbo engine in my mk3 cabby i have a complete engine and loom from a fiesta rst would i be able to use that or do i need one out of an escort? any help much apreciated
Hi mate loads have used the rst fiesta as long as you got ecu and fuel ecu you will have to get a fuel pump out of efi turbo aswell not sure what else you need but grin and bear it and post problems as you go some one will answer you probs :banana_dance: hope this helps
well i have the complete car as its my brothers and he putting cossie lump in his so i should be able to get nearly all the main parts from him its just the turbo that is bigger too
Guest steelcabby
if yours is an xr3i injection mk3. you will be fine with what you got. tank and fuel pump will be fine
if you have a carb xr3 cabby, your need fuel tank and returns, fuel pump and loom from an escort EFI.
if you get an escort EFI loom it will make you life very easy. then all you have to do is plug the fezzy ecu in and swap acouple of wires over to get it running. well depending on weather you have ofab or ofac management from the fiesta??
