Guest Stally08 Posted December 6, 2009 Share Posted December 6, 2009 i wasnt sure where to put this so i put it in here, when i pull the bonnet pull the bonnet opens but when i lift the catch it doesnt open, the only way to open it is if i keep the bonnet pull under the steering wheel pulled and then leift the catch, any suggestions on what it could be? Quote Link to comment Share on other sites More sharing options...
Admin Paul Posted December 6, 2009 Admin Share Posted December 6, 2009 It sounds like its not releasing the bonnet, there is adjustment on the bonnet catch both side to side and also you can compress the spring a little with a flat blade screwdriver I guess you just need to play with it for 30 mins Paul Quote Link to comment Share on other sites More sharing options...
Guest markeyboy Posted December 7, 2009 Share Posted December 7, 2009 give it a grease up too they do tend to pick up quite a bit of road grime over the years Quote Link to comment Share on other sites More sharing options...
Guest shaun Posted December 7, 2009 Share Posted December 7, 2009 Hi i would try spraying wd40 or something like that on catch 1st to see if that helps then try adjusting it could be both as said by other's...hope this help's Quote Link to comment Share on other sites More sharing options...
