Guest xr2madman Posted November 28, 2009 Share Posted November 28, 2009 hi all could some one help me i have a mk3 escort b reg 1.6 l not a cab but hey still trying to get one it runs ba din the morning and when i put my foot down it pinks it runs better when warm but still pinks please guys i need your help as realy love the car but its driving me mad many thanks damian Quote Link to comment Share on other sites More sharing options...
Guest Haddow Posted November 28, 2009 Share Posted November 28, 2009 have you checked the wiring to your ecu? might be a problem with the ecu somewhere thats causing it mate if it was me thats what i'd check first. Quote Link to comment Share on other sites More sharing options...
Guest mossop1 Posted November 28, 2009 Share Posted November 28, 2009 i would go get youre local garage to check the timing with strobe light as sounds bit advanced to me and with leaded fuel nolonger being available the old cvh engines do pink if not slightly retarded on the timing. Quote Link to comment Share on other sites More sharing options...
ianxr3i Posted November 29, 2009 Share Posted November 29, 2009 I would get your ignition timing checked. Does your car have a blue cap (Motorcraft) on the distributor or a red one (Bosch). If it has a blue cap, it might be the ignition module on the case of the distributor breaking down under load. When I worked in a ford main dealer in colchester, we changed the distributors over from motorcraft to bosch distributors because of this problem with the ignition modules. Hope this helps Quote Link to comment Share on other sites More sharing options...
