Guest chunk Posted November 26, 2009 Share Posted November 26, 2009 hi im putting a frst engine in my mk4cab what will i have to change on the body to fit the engin,will the original engine mounts fit the fiesta turbo engine and the engine is a 1.9 zvh i think itsgot a 1.8 bot end and a 1.6 top thanks Quote Link to comment Share on other sites More sharing options...
Guest steelcabby Posted November 26, 2009 Share Posted November 26, 2009 does it not come with the mount attached to it?? fiesta and escort engines mount the same mate, but if you need to use your engine mount for the zetec bottom end? it will have to be modified. not all the holes line up, so you will have to cut and weld the last hole, plus i think IIRC you need to cut another section out to miss the cam belt tensioner. Quote Link to comment Share on other sites More sharing options...
Guest chunk Posted November 27, 2009 Share Posted November 27, 2009 thanks mate ill have to get on it Quote Link to comment Share on other sites More sharing options...
Guest Andy Posted November 27, 2009 Share Posted November 27, 2009 http://www.escortupgrades.co.uk/Escort%20Upgrades/Escort%20Upgrades%20Index.html click on engines then zetec then zetec fittment mate tells you with pic what you need to mod Quote Link to comment Share on other sites More sharing options...
