Mk4 Cab Turbo Project
Guest chunk
hi im putting a frst engine in my mk4cab what will i have to change on the body to fit the engin,will the original engine mounts fit the fiesta turbo engine and the engine is a 1.9 zvh i think itsgot a 1.8 bot end and a 1.6 top thanks
Guest steelcabby
does it not come with the mount attached to it??
fiesta and escort engines mount the same mate, but if you need to use your engine mount for the zetec bottom end? it will have to be modified. not all the holes line up, so you will have to cut and weld the last hole, plus i think IIRC you need to cut another section out to miss the cam belt tensioner.
