Guest shaneb677 Posted November 26, 2009 Share Posted November 26, 2009 ok it all started couple of weeks ago i went out in the car in the dark so naturally i put the lights on i got a little way about a mile then it just died lights went dim to its got new alternator had battery tested and halfords reckon the altrnator is not charging battery but he could not be sure now today i went out to the car and this is what happend i put key in turnd it no battery light never seen it light up since i have had the car also lots of electrical noises in drivers footwell or in dash next to stering wheel also fuel pump at the rear of the cabby just kept going did not make the normal sound . lots of power in battery if anyone can give me a check list i can go by i will be greatful .... i no nothing about electrics but i want this cabby sorted hate seeing it just sitting there its disartning so please if you can advise would be great.... Quote Link to comment Share on other sites More sharing options...
Guest busadaddy Posted November 26, 2009 Share Posted November 26, 2009 what cab is it Quote Link to comment Share on other sites More sharing options...
Guest shaneb677 Posted November 26, 2009 Share Posted November 26, 2009 what cab is it sorry m8 mk4 Quote Link to comment Share on other sites More sharing options...
Guest Cabbytech Posted November 26, 2009 Share Posted November 26, 2009 All the noises you heard when you turned the key were probably the relays etc all fighting for power from your battery, its possibly an earth problem you have, check the battery earth connection and also the earth to the carbody and engine. Put a voltage meter on the battery before starting the car and see what standing volts you get, an average is between 12.6v to 12.8v depending on weather conditions and usage for a charged battery, once the car is running, hold it at about 2500 rpm and put the meter on again and see if the voltage has increased, you should now be getting between 13.5v to 14.5v as an average, again this could vary slightly depending on the battery and alternator output, this is a quick test to show that the alternator is working Quote Link to comment Share on other sites More sharing options...
