Guest rickey Posted November 17, 2009 Share Posted November 17, 2009 Can any one tell me if i can fit power steering to my Mk 3 16.i Cabrolet Quote Link to comment Share on other sites More sharing options...
Guest markeyboy Posted November 17, 2009 Share Posted November 17, 2009 it has been done in the past, they use the steering rack off somthing french there are people on here who now how its done, im afraid im no help tho Quote Link to comment Share on other sites More sharing options...
Guest shaun Posted November 17, 2009 Share Posted November 17, 2009 Hi I have seen power steering on mk3-4 escorts.Dont know what bits you need but have seen power steering on e-bay for a mk4 escort Quote Link to comment Share on other sites More sharing options...
Guest Cabbytech Posted November 17, 2009 Share Posted November 17, 2009 (edited) I have never personally done this conversion but I believe there are 2 avenues for you to look at, the first one is a power steering rack off a mk5, along with the bottle and pipes, pump and pulley etc, (i think the pump and pulley can come from a ka or fiesta as well) i do know that this method has been done before, and i think the rack has to be rethreaded to accept the mk3/4 track rod ends, hopefully someone else can confirm or clarify this, the other option is to try and find a disability escort, some of these had a conversion done where PAS was fitted, but obviously these cars will be like rocking horse you know what to find. Edited November 17, 2009 by Cabbytech Quote Link to comment Share on other sites More sharing options...
Guest KarlosG Posted April 6, 2010 Share Posted April 6, 2010 3rd Option is to use a Corsa D electric PS column and controller, you fit it inbetween the top and bottom of your current column and make up a bracket to secure it to the pedal box/bulkhead, can even be wired to the speed sender on the gearbox (if you have one) and be variable or you can set the assistance to a level of your choosing using a varible resistor! Quote Link to comment Share on other sites More sharing options...
