Guest Johann Posted November 15, 2009 Share Posted November 15, 2009 (edited) hi guys any idea my cab is very very little jerking at low rev 2,000. than on the road it is very lazy it doesn`t go higher than 4,000 rev. tried to change air flow sensor but still no difference. when i`m working and return home it never give me any problems to start. after maybe 4-6 weeks sitting in the garage. Edited November 15, 2009 by Johann Quote Link to comment Share on other sites More sharing options...
Guest markeyboy Posted November 15, 2009 Share Posted November 15, 2009 if it wont rev it may be a sign that the kat is breaking down, mine got so bad that it wouldnt rev past 2.5k Quote Link to comment Share on other sites More sharing options...
Guest Johann Posted November 16, 2009 Share Posted November 16, 2009 i was speaking to a guy and he told me it coulkd be the throttle position sensor. could it be before i start buying parts ? Quote Link to comment Share on other sites More sharing options...
Guest DaveG79 Posted November 16, 2009 Share Posted November 16, 2009 Get your exhaust system checked out. My wifes had the same problem and it turned out that the back box had disintegrated inside and the bits were making theere way back up along th eexhaust pipe thus blocking it. Quote Link to comment Share on other sites More sharing options...
Guest markeyboy Posted November 17, 2009 Share Posted November 17, 2009 you can check the tps with a meter you should see a resistance that gradually increaces or decreace (cant remember) as the pot is turned, if its a smooth increace its usually ok if it jumps about then its usually knackered Quote Link to comment Share on other sites More sharing options...
Guest shaun Posted November 17, 2009 Share Posted November 17, 2009 Hi mate before you try anything try dis-connecting cat from centre box as mine was the same wouldnt rev over 4000rpm and the baffle in back box had broken and blocked tail pipe so no gases could get out.I cut back box open and found all the silencer sound deadening had got wet and stuck over the tail pipe exit so it wouldnt push it out.... Does yours lose power going up hill so you have to change down into lower gear when you know it would norm go up there?? Hope this helps Quote Link to comment Share on other sites More sharing options...
Guest Johann Posted November 21, 2009 Share Posted November 21, 2009 no it doesn`t lose power going up the hills it is like it weon`t rev more than 4,000 and that`s it even parked and when i fully depress the pedal still the same . regartding the silencer i have to check it out because i`m sure back box is stainless steel and only fitted year ago middle box i don`t have so basically from kat to the rear end it is new. now i am being told that it is because i don`t use the car. keep in mind that it has got only 20k on the clock from new true but i don`t beleive that. but i have to check out properly in 2 weeks time cause i`m working abroad at the moment. cheer to all the help guys Quote Link to comment Share on other sites More sharing options...
Guest hoochydady Posted December 17, 2009 Share Posted December 17, 2009 hi it could be a few things fuele pump prob? throttle cable adujtment not rite? poss ecu fault limp home mode?id say get hooked up to a fault finder see what comes up Quote Link to comment Share on other sites More sharing options...
Guest Johann Posted April 11, 2010 Share Posted April 11, 2010 hello people after a long time in the garage doin nothing i`ve decided to take a good look around and i` ve managed to solve out one of the problems i`ve cleaned the air flow sensor and now it is ok it`s rev up as it should do but still between 1500-2000 revs it has got a little misfire and next job is going to be fiddle a bit with the tps or order a new since in malta we don`t have those kind of parts of the shelf !!!!!! cheers johann Quote Link to comment Share on other sites More sharing options...
