S2 Rs Anti Roll Bars
Guest Haddow
as title really, are the xr3i cab arb's any different to the rs turbo ones? or are they the same diametre etc? im sure that the rs ones are a bit stronger or thicker? just wondering as im breaking the donor cab at present and also a series 2 rs to rob parts for my cab, sacralige i know killing an rs turbo and i'd get linched on PF for it, but who cares lol.
any help would be appreciated if anyone knows the answer to that question. cheeRS
Neil
Neil
The rs and xr3i are not the same. In turbo they are thicker, front 22mm vs.24mm and 14mm vs. 16mm and back. I have do the swap.
  • Admin
The XR3i Cab are the same as the RS turbo 24mm, the anti roll bar is not fitted to the rears on the XR3i Cab, maybe Finland specs are different
Paul
Paul
Ok. Every cabs i have seen in Finland have anti roll bar in rear. Rs turbos in here have thicker roll bars. Different country and different specs...
Sorry, bad english
i'll measure them out just to be sure on my rs turbo and cab, i'll be taking the rs apart for the crusher soon anyways so the rear anti roll bar will be making its way onto my car anyways, thanks for the info, cheers
neil
