Guest jamesabrown Posted October 23, 2009 Share Posted October 23, 2009 Hi All, I have a problem with my lovely car and really need to see if anyone can help me because like most people at the moment I cant afford to take my car to a garage! I have a mk4 1989/90 escort xr3i cabriolet and I love it to pieces, its the 1.6 efi version. Over the past few months it will occassionaly cut out and then not start for a while but I just got back off holiday a few weeks ago and now it wont start at all I have checked a few things - It has a new battery, alternator, service, plugs etc and their is a spark when turning over the engine but unfortunatley it just wont start - i am also preety sure that fuel is being pumped but for some reason its just not firing or starting up. Please can anyone help me? I thought maybe the Crank position sensor but as far as i know or found out recently it does not have one! Can anyone help? Thank you so much. James x Quote Link to comment Share on other sites More sharing options...
Guest jamesabrown Posted October 23, 2009 Share Posted October 23, 2009 update - the car does have a crank position sensor could it be this? Quote Link to comment Share on other sites More sharing options...
Guest diggy Posted October 23, 2009 Share Posted October 23, 2009 are you certain the fuel is goin through? have you checked the fuel cut off in the boot? Quote Link to comment Share on other sites More sharing options...
Guest jamesabrown Posted October 23, 2009 Share Posted October 23, 2009 Humm I will have a look at the fuel cut off but i think its going through, what do i have to look for? Quote Link to comment Share on other sites More sharing options...
Guest diggy Posted October 23, 2009 Share Posted October 23, 2009 Humm I will have a look at the fuel cut off but i think its going through, what do i have to look for? under the spare wheel there is a little switch that sometimes gets pressed in result the fuel won't go through. hope this helps Quote Link to comment Share on other sites More sharing options...
Guest Cabbytech Posted October 23, 2009 Share Posted October 23, 2009 hmmmm, it could also be either your cold start valve or the warm up regulator that is causing the problem, Quote Link to comment Share on other sites More sharing options...
