Mk5 Escort 1.6 Efi Cvh Jerking At Low Speed
Guest BAVO
Hi I have a 1990 Mk5 escort cabriolet 1.6 efi cvh jerking at low speed, it seems to miss and then pick up again, I have replaced the ISCV and throttle sensor ( the black thing near throttle body ) which has made it a bit better, also done the plugs and leads. You could be doing 30 mph in 4th gear and then it misses and picks up again very annoying, it runs well at high speeds and will go all day without missing a beat. Its done 100k miles and doesnt use oil or water. Today I took the plug of the throttle sensor ( new ) and it didnt make any different when revved up, so maybe its that ? Any other ideas chaps ?post-9652-12553707897981_thumb.jpg
Guest suffolk04
is the coil pack cracked?? only has to be small for them to break.
hope you get it sorted, i have the same problem on my mk4 efi, and like you changed tps,leads,iscv and air temp sensor(plugs next)
could be emissions fault,fuel pump/relay fault,keep us updated
Hi thanks for your advice, about 2 months ago I took it to a garage ( after changing the iscv which made a little better ) The mechanic checked it over with a mutimeter and said the throttle control sensor was faulty, these are not available from Ford anymore so ordered a pattern part. The car was then 95 % better until now when its started to happen again. So last weekend I took of the throttle sensor and sprayed that and the throttle body with WD40 its now a lot better so deffo that is causing the problem. Need to find a good second hand Ford one Ford part number 91XF 9B989 AA, Ford Finis 6539215.
Cheers Steve
Edited by BAVO
Guest suffolk04
Cheers Steve
thanks, but mines still struggling, did yours do it all the time?? mines ok when cold, but stutters & hesitates when warm. so i'm thinking emissions or coolant temp sensor
Mine was the opposite it was okwhen cold probably cos the choke compenstated. It seems a lot better now spraying the Throttle sensor with wd40 inside. But still would like to find a good 2nd hand one, that one on e bay is a bit pricey
Hmmm, that part no doesnt even exist in the Lucas cross reference guide, but i found this one as per your part numbers on ebay lol
http://cgi.ebay.co.uk/Throttle-Position-Sensor:-Ford-CVH-1.6EFi-&-Fiesta-RS_W0QQitemZ150356268641QQcmdZViewItemQQimsxq20090930?IMSfp=TL090930151004r22014
Cheers for that but a lot of money for a bit of plastic lol
Guest suffolk04
changed coolant temp sensor,still the same. so had the emissions checked, running on near enough air only, so richened it up, and its still happening :unsure:
going to try the ecu reset see if that helps.
Hmm how do you reset the ECU ?
And good luck in finding the problem
Keep us updated
Guest suffolk04
unplug ecu or disconnect battery (easier access) leave off for a few minutes (i'm going for 30mins) then its something like let the car idle for a few minutes, then take it for a drive using different throttle positions and speeds to relearn its values.
Sorry mate the part number is 89sf-9b989-ab not the one I put on previously, still cant find it any help appreciated
Guest suffolk04
right, narrowed it down to a few things, here we go....Injectors,fuel pressure regulator,tappets(maybe?) idle speed control valve,ecu
Dont you just love cars
Especially elderly Fords !
Expensive trial and error process, cant you get a mobile tuner to find out the prob ?
Edited by BAVO
Guest suffolk04
tried ringing one, but doesn't have any equipment for older cars, great, especially when the list is getting bigger, so add map sensor to the list.
any luck with yours?
well, mines cured!! :banana_dance: Map sensor fault, runs perfect now.
Congrats
Mine is still playing up even adter fitting a different tcp and resetting the computer
How did you find the error on yours ? Did you try different bits ? And where is the map sensor
Cheers Steve
Guest suffolk04
map sensor is on the bulk head, on 2 screws on the plastic heater thing, its a black rectangle with 2 screws either side of it.
yeh pretty much trial and error, spent just over £100 on bits that didn't need doing, turned out to be the map sensor which i had in my shed for about a year.
hope this helps,
steve
  • 2 weeks later...
hope this helps,
steve
Ok ta thanks, do you have a spare one I could try ? Also any idea where the IAT sensor is, I know it should be on the air intake before the throttle body and MAF but cant see anything
Cheers Steve
Guest suffolk04
its on the inlet manifold. if you look at the engine head on from the front, its screwed in on the right hand side with a multi plug connected.
I dont have a spare one i'm afraid, but have a look on ebay for ones being broken, you could buy from ford, but they cost £210+vat
Guest honeywheels
hi guys and any ladies . like yourself i am having the same type of problems with my honey. does any one now wher i can get a purge solinoid valve for a 1.6efi cvh 1990 . i hear that ford charge 80 pound to put the car on the computer and it tells you what is wroung i think i will end up trying it
