Guest Evo Posted October 11, 2009 Share Posted October 11, 2009 (edited) i am having problems with my engin when i break the engin starts 2 rev up any one no what it is an how 2 fix it thanks Edited October 11, 2009 by Evo Quote Link to comment Share on other sites More sharing options...
Guest Cabbytech Posted October 11, 2009 Share Posted October 11, 2009 I take it that it revs up when you dip the clutch to between 2000 and 3000 rpm, and then does it settle down once the car stops moving ? if so then the idle speed control valve may need a good cleaning or changing. Quote Link to comment Share on other sites More sharing options...
Guest Evo Posted October 11, 2009 Share Posted October 11, 2009 thanks mate i will have a go of changing it is it easy 2 change Quote Link to comment Share on other sites More sharing options...
Guest Cabbytech Posted October 12, 2009 Share Posted October 12, 2009 Its quite an easy job, prob just needs some gunge cleaning off it. Quote Link to comment Share on other sites More sharing options...
Guest markeyboy Posted October 12, 2009 Share Posted October 12, 2009 failing that it could be a vacuume leak, had this problem for a while on mine, turned out it was a blanking plat on the inlet manifold Quote Link to comment Share on other sites More sharing options...
Guest Evo Posted October 12, 2009 Share Posted October 12, 2009 thanks am goin to clean it all first see if that works an if not is the blanking plat on the inlet manifold easy to fix or replace Quote Link to comment Share on other sites More sharing options...
Guest markeyboy Posted October 13, 2009 Share Posted October 13, 2009 dont know mate, ford ended up doing mine, i went down the route of changing lots of related bits myself, cost a fortune lol Quote Link to comment Share on other sites More sharing options...
Guest Evo Posted October 13, 2009 Share Posted October 13, 2009 hahaa i no just got a load of cleaning stuff that cost me £30 would of been cheaper to get it fixed haha Quote Link to comment Share on other sites More sharing options...
