Guest clacky Posted September 28, 2009 Share Posted September 28, 2009 Hi Guys and Girls Need some help !! I would like to remove the 2 front doors, is there an easy way to remove the pins or do i need a special pin removal key. (Have tried to drift them through but a little afraid of mushrooming the top of the pins and then i would never get them out ) Ideally i dont want to go down the remove the hinge nuts from the inside of the dashboard etc as they are buried well deep and i'm not a contortionist ))) ....... All help appreciated CHeers Chris Quote Link to comment Share on other sites More sharing options...
Guest dee1orean Posted September 28, 2009 Share Posted September 28, 2009 I tried to remove the door pins with a universal pin removal tool but had no luck, ended up removing the bolts from inside the car, soz mate I know it's not what you want to hear but may be the easiest way. Quote Link to comment Share on other sites More sharing options...
Guest clacky Posted September 28, 2009 Share Posted September 28, 2009 Thanks for the reply, not what i wanted to hear but maybe its the only way !! Seems a real bad design by Ford as there appears to be plenty of room to have the nuts on the outside of the hinge.... :taz: Am I am right in thinking that the top pin should be removed in a downward direction and the bottom pin is upwards , after removing the tiny circlips that are at the top and bottom of the pins?? Might just WD40 them and then bash the crap out of them with a large drift bar :teu26: :teu26: Cheers Chris Quote Link to comment Share on other sites More sharing options...
