Guest pauls0701 Posted September 27, 2009 Share Posted September 27, 2009 just brought a mk6 nd the front door inside trim panels are in need of replacement its the bit that has got the fabric on that needs replacing is it possible to replace just that bit or does the whole panel have to be changed Quote Link to comment Share on other sites More sharing options...
Guest dave29 Posted October 19, 2009 Share Posted October 19, 2009 just brought a mk6 nd the front door inside trim panels are in need of replacement its the bit that has got the fabric on that needs replacing is it possible to replace just that bit or does the whole panel have to be changed it is doable but involves alot of patience n spray glue lol.if you can get a door card to match the rest id just replace the whole thing. Quote Link to comment Share on other sites More sharing options...
