Guest Shortie Posted September 27, 2009 Share Posted September 27, 2009 Wondering how you get the top part of the rear seats out? See image http://tinypic.com/r/10o40go/4 Any help more than welcome Thanx Shortie Quote Link to comment Share on other sites More sharing options...
Guest djk Posted September 27, 2009 Share Posted September 27, 2009 Just did this yesterday! With the roof up look over the back of the headrest and you'll see the back is covered in ribbed carpet; 1. Remove the roof cover stud at the top outside edge each end, best done with the roof up. 2. remove the two screws, one above each other, about 150mm (6 inches) further inboard on each side 3. Now lower the roof and at each end of the headrest there is a screw from the side that goes into the headrest, you will need to raise the roof slightly as the frame gets in the way. remove each one. Now your headrest should come away by pulling it upwards... Need any more help I'll take some pics and send them. David Quote Link to comment Share on other sites More sharing options...
Guest Shortie Posted September 27, 2009 Share Posted September 27, 2009 Will go see thanx Quote Link to comment Share on other sites More sharing options...
Guest Shortie Posted September 27, 2009 Share Posted September 27, 2009 http://tinypic.com/r/ab2sk7/4 Have done what you said, have marked the image with what i have removed, 2 screws either end and the two at the back either side but does not lift out. Any other ideas, do you have to do anything with the seat belts? Quote Link to comment Share on other sites More sharing options...
