Guest richie29gt Posted September 25, 2009 Share Posted September 25, 2009 right ok here we go have clean the icv and oil breather and cleaned the throttle assembly have checked to see if the tps works 2 which it does so wot else could it be have checked all over breather pipes please help some 1 as this is really starting to get on me titis Quote Link to comment Share on other sites More sharing options...
Guest Cabbytech Posted September 25, 2009 Share Posted September 25, 2009 Check the vacuum pipes, you might be suffering from an air leak, possibly around the servo, making the mixture weak and hence stalling, one of the vac pipes might have a small hole in it. have you given the butterfly in the throttle assembly a good wipe, it can get a build up on black gunge around the edge that causes stalling, Quote Link to comment Share on other sites More sharing options...
Guest suffolk04 Posted September 29, 2009 Share Posted September 29, 2009 any look? i have the same problem, and have found an air leak on the servo pipe going into the inlet manifold. Can't get hold of one at ford(no longer in service) so gunna have to repair or find one. fingers crossed this will fix it, fed up with re-starting 4-5 times a day Quote Link to comment Share on other sites More sharing options...
Guest smoothy582 Posted September 29, 2009 Share Posted September 29, 2009 Hi richie i can have at look at it for you if your ever nearby let us know cheers rich My link Quote Link to comment Share on other sites More sharing options...
