Guest diggy Posted September 25, 2009 Share Posted September 25, 2009 there seems to be a bit of movement when i rev up and change gear. checked the engine mounts and all are tight. i suspect they may be worn so my next question is are they easy to replace? the car is a mk4 Quote Link to comment Share on other sites More sharing options...
Guest Cabbytech Posted September 25, 2009 Share Posted September 25, 2009 It does sound like an engine or gearbox mounting to me mate, on a mk4 they are not too bad to replace, from experience i usually find its the front gearbox one that goes first. hope this helps. Quote Link to comment Share on other sites More sharing options...
Guest diggy Posted September 25, 2009 Share Posted September 25, 2009 i might replace all of them i think better to do all the work in one go thanks for the help Quote Link to comment Share on other sites More sharing options...
