Guest suffolk04 Posted September 23, 2009 Share Posted September 23, 2009 happened twice now, once when cold on the way to work, then again on the way back engine warm. its a mk4 efi, battery just over 2 years old,(sealed type) i think battery, but don't know if there are any other common faults Quote Link to comment Share on other sites More sharing options...
Admin Paul Posted September 24, 2009 Admin Share Posted September 24, 2009 Will not be the battery mate, maybe the fuel pump relay Quote Link to comment Share on other sites More sharing options...
Guest suffolk04 Posted September 24, 2009 Share Posted September 24, 2009 i'll check that as well thanks. Wouldn't it be cutting out all the time though? been advised to check the iscv, but it's fairly new, and my fault code reader didn't fault it. Was thinking battery because i got a starter on it that takes a lot of amps and turns over slow when starting, and because i'm doing around 15 miles a day, the battery isn't charging the battery enough Quote Link to comment Share on other sites More sharing options...
Guest suffolk04 Posted September 25, 2009 Share Posted September 25, 2009 anyone got the part number for the pink relay? i went to ford armed with part number 6145938, turns out its a yellow relay for a cosworth. Quote Link to comment Share on other sites More sharing options...
