Guest spaceman Posted September 21, 2009 Share Posted September 21, 2009 Evening all. I need to change this on my Mk4 XR3i but don't want to spend £200 plus getting Fords to do it! I have done one before but it leaked soon afterwards. Does anyone have any hints or tips on how to fit one without the spring coming off. What distance piece can be used to get it into position? Thanks guys. Quote Link to comment Share on other sites More sharing options...
Guest spaceman Posted September 22, 2009 Share Posted September 22, 2009 Evening all. Has nobody fitted these themselves? Had a few views but no reply's, can anyone help? I think the best bet is to smear with grease on outside edge and try and get in in with finger pressure-is this right? Thanks Quote Link to comment Share on other sites More sharing options...
Guest spaceman Posted September 23, 2009 Share Posted September 23, 2009 Good Morning. Can anyone help with crank front oil seal fitting advice on CVH this morning? Quote Link to comment Share on other sites More sharing options...
Admin Paul Posted September 23, 2009 Admin Share Posted September 23, 2009 Hi, i changed one on mine mate and wasnt that bad. I just used a typical silicone bathroom sealer tube and cut the bottom of it. This worked well cause it was hard plastic. Just make sure its sits centre before tapping it home. The hardest part was making sure the cam belt went on again in teh same place. Plenty of tip ex did that tho Use a genuine seal, £20 from Fords Paul Quote Link to comment Share on other sites More sharing options...
Guest spaceman Posted September 24, 2009 Share Posted September 24, 2009 Hi, i changed one on mine mate and wasnt that bad. I just used a typical silicone bathroom sealer tube and cut the bottom of it. This worked well cause it was hard plastic. Just make sure its sits centre before tapping it home. The hardest part was making sure the cam belt went on again in teh same place. Plenty of tip ex did that tho Use a genuine seal, £20 from Fords Paul Thanks Paul, I have made my own distance piece from wood now and will be trying tomorrow so will let you know, when I have done it before the spring always pings off! Quote Link to comment Share on other sites More sharing options...
