Guest suffolk04 Posted September 12, 2009 Share Posted September 12, 2009 Did a engine compression test today to figure out whats causing my misfire at idle only. Heres what i got: Cylinder 1= 135psi Cylinder 2= 150psi Cylinder 3= 140psi Cylinder 4= 150psi The problem is with cylinder 1, but anyone know what the original compressions should be? Had a look in the haynes manual, but can't find them. Quote Link to comment Share on other sites More sharing options...
Guest mossop1 Posted September 12, 2009 Share Posted September 12, 2009 they aint that bad i would not worry about em anything below 100 is when its time to pull engine out and rebuild you checked inlet manifold for vacum leak as thats could cause missfire at low revs as screw the mixture up. Quote Link to comment Share on other sites More sharing options...
Guest suffolk04 Posted September 12, 2009 Share Posted September 12, 2009 yeh everything else is fine, its not that bad, you can just feel it when the car is idle, running rough/lumpy. but it's fine when driving to narrowed it down to cylinder/valves. Cars done 145000 miles, so moon and back :icon_salut_gb: doubt its ever been stripped was just trying to compare the compressions to a new engine, can't seem to find anything though anyone know?? Quote Link to comment Share on other sites More sharing options...
Guest suffolk04 Posted September 13, 2009 Share Posted September 13, 2009 had a look through a friends mk5 haynes manual, compression ratio a bit different(mk4 9.5.1)-(Mk5 9.75.1) both 1.6 cvh engines and the compressions should be around 175-205psi. gunna leave it for now, but definitely going to buy the newer haynes manual, mines abit dated now(old purple version) Quote Link to comment Share on other sites More sharing options...
Guest suffolk04 Posted September 15, 2009 Share Posted September 15, 2009 anyone know how much it costs to have and engine fully re-built? One website quoted me £795+ delivery and extras, Quote Link to comment Share on other sites More sharing options...
Guest mossop1 Posted September 15, 2009 Share Posted September 15, 2009 I would try and find a local engine recon firm as i would think you could get it all done for 600 notes i know of one in birmingham they call them selfes blue star and did good work or if youre south coast try tik engineering they are good.hope that helps. Quote Link to comment Share on other sites More sharing options...
Guest suffolk04 Posted September 16, 2009 Share Posted September 16, 2009 i know theres a place in nottingham (my town), that do headgaskets,skimming and the rest of the work to the cylinder head, so might be worth giving them ago i suppose. Their called R.B lindley's and son, anyone from the midlands area used them, or know anyone who used them? Quote Link to comment Share on other sites More sharing options...
Guest tacha_maree Posted September 17, 2009 Share Posted September 17, 2009 if your not modifying the engine its fairly easyto do yourself, im rebuilding a cossie engine atm. just make sure you have a workshop manual so you get you tolerances and torque setting right. the replacement parts are cheapish... you only need a torque wrench basic socket set, piston ring compressor and a magnetic screwdriver for the collets... obviously get the head machined professionally but isnt difficult to do. Quote Link to comment Share on other sites More sharing options...
Guest mikecurd Posted September 17, 2009 Share Posted September 17, 2009 Tech data says 12-14 bar. Quote Link to comment Share on other sites More sharing options...
Guest suffolk04 Posted September 28, 2009 Share Posted September 28, 2009 Tech data says 12-14 bar. yeah found that too on autodata, i'm getting between 9-10 bar so a little worn, but after 144k miles, not too bad.....yet Quote Link to comment Share on other sites More sharing options...
