Guest cabbyxgirl Posted September 8, 2009 Share Posted September 8, 2009 Hi does anyone know where i can buy a webber fuel pressure regulator for my 1990 efi xr3i cabby? cant find anyone selling them online and none of my local shops can get one. many thanks x Quote Link to comment Share on other sites More sharing options...
Guest murcus Posted September 8, 2009 Share Posted September 8, 2009 Hi does anyone know where i can buy a webber fuel pressure regulator for my 1990 efi xr3i cabby? cant find anyone selling them online and none of my local shops can get one. many thanks x hi you can either change it for an fse fuel pressure regulator, boost valve, or try drilling or prizing off the cap at the top and turning the allen key inside to let more fuel through Quote Link to comment Share on other sites More sharing options...
Guest sandman2209 Posted September 9, 2009 Share Posted September 9, 2009 hi i think ive got 1 on my cab available Quote Link to comment Share on other sites More sharing options...
Guest cabbyxgirl Posted September 9, 2009 Share Posted September 9, 2009 how much do u want for it? email me at petrolheadjim@hotmail.co.uk hi i think ive got 1 on my cab available Quote Link to comment Share on other sites More sharing options...
Guest cabbyxgirl Posted September 9, 2009 Share Posted September 9, 2009 mine is bolted on the end of the fuel rail i popped of the cap about the size of a 5p of the front but there was no allen key bolt?. How could i use a fse reg. or boost valve the fuel flows through the regulator into the fuel rail? Quote Link to comment Share on other sites More sharing options...
Guest murcus Posted September 10, 2009 Share Posted September 10, 2009 mine is bolted on the end of the fuel rail i popped of the cap about the size of a 5p of the front but there was no allen key bolt?. How could i use a fse reg. or boost valve the fuel flows through the regulator into the fuel rail? after you prize off the cap there is an allen bolt inside to turn, think i had to scrape a bit if i remember, if you add on a fse regulator, it takes the place of the bosch unit a new one is around 69 pounds for fse boostvalve, all you have is 2 bolts a rubber seal for the inlet, the fuel pipe that feeds from the bottom, and a breather pipe at the top if i remember correctly, the same one foe the efi is also used on the 205 gti Quote Link to comment Share on other sites More sharing options...
