Guest cabbyxgirl Posted September 6, 2009 Share Posted September 6, 2009 Hi everyone ive got a mk4 xr3i cabby with the efi engine. When i bought it a couple of weeks ago it was running a bit lumpy at lower revs and was kangarooing and occasionally stalling. I did a service changed the air filter and spark plugs, the ht leads looked fine almost new and the problem remained so i put in a bottle of injector cleaner, no change. So i changed the idle control valve for a brand new item and still it kangaroos at lower revs. Ive run out of idea's now i cant find any split air pipes either. oh and i have unplugged the battery to reset the ecu too. Has anyone got any other ideas for things i can try? Your help is much appreciated x Quote Link to comment Share on other sites More sharing options...
Guest tacha_maree Posted September 7, 2009 Share Posted September 7, 2009 its your map sensor or a air leak somewhere. mine did the same Quote Link to comment Share on other sites More sharing options...
Guest murcus Posted September 7, 2009 Share Posted September 7, 2009 its your map sensor or a air leak somewhere. mine did the same as above or your fuel filter is needing changed Quote Link to comment Share on other sites More sharing options...
Guest cabbyxgirl Posted September 7, 2009 Share Posted September 7, 2009 thanks for the replies guys, i cant find an air leak and i have changed the fuel filter. Whats my map sensor and where would i find it? Your help is much appreciated. x Quote Link to comment Share on other sites More sharing options...
Guest murcus Posted September 7, 2009 Share Posted September 7, 2009 (edited) hopefully this helps you out, ive found ones on ebay for you to look at, then you will find it no probs http://cgi.ebay.co.uk/Ford-coil-pack-map-sensor-and-edis4-module-EFI-models_W0QQitemZ150369932478QQcmdZViewItemQQptZUK_CarsParts_Vehicles_CarParts_SM?hash=item2302bf14be&_trksid=p3286.c0.m14 edis 4 module, map sensor and coilpack sorted Edited September 7, 2009 by murcus Quote Link to comment Share on other sites More sharing options...
Guest suffolk04 Posted September 7, 2009 Share Posted September 7, 2009 try disconnecting the throttle position sensor and then road test, mine used to kangeroo and cut out, i changed leads,plug,coil,map sensor and idle control valve costing me a bit,turned out to be the tps. Quote Link to comment Share on other sites More sharing options...
Guest cabbyxgirl Posted September 8, 2009 Share Posted September 8, 2009 Thanks for all the replies people, I have found out what the problem is! Fuel pressure regulator! I took the vacuum pipe of and the car runs like a dream! Having trouble finding a new one though my local auto parts shops dont stock and cant get the webber one i need, does anyone know where i can get one? Hope this helps someone else who have the same symptoms! Thanks guys x Quote Link to comment Share on other sites More sharing options...
