Guest Jaygo Posted September 2, 2009 Share Posted September 2, 2009 (edited) Hello Ive had my XR3i 2 months and not had a problem, Until monday after traveling back from York to Nottingham droped a friend of, stoped the engine helped unpack his stuff jumped back the car turned engine over wont start left it 10 mins tryed again the engine fired once but nothing else.. Can any one help? Edited September 2, 2009 by Jaygo Quote Link to comment Share on other sites More sharing options...
Admin Paul Posted September 2, 2009 Admin Share Posted September 2, 2009 MFI? EFI? MK4? need more info mate Quote Link to comment Share on other sites More sharing options...
Guest Eggsy Posted September 2, 2009 Share Posted September 2, 2009 If its mk3/4 its 90% the pink fuel pump relay - I have plenty of them spare Quote Link to comment Share on other sites More sharing options...
Guest Lee81 Posted September 2, 2009 Share Posted September 2, 2009 Pink relay under the drivers side dash. They burn out over time and become very intermitent in working. Be careful as the voltage to the pump will become low and may pulse. Car will still run but will lean out the fuel mix causing detonation Very common fault Quote Link to comment Share on other sites More sharing options...
Guest StarLoc Posted September 3, 2009 Share Posted September 3, 2009 (edited) I had similar on mk4 xr3i, i put a load of stuff in the boot, drove, unpacked it and then the car would not start, occasionaly firing , it was the relay with the button on in the spare wheel well, press the button and the car would then start, its a shock sensor Edited September 3, 2009 by StarLoc Quote Link to comment Share on other sites More sharing options...
Guest tacha_maree Posted September 4, 2009 Share Posted September 4, 2009 the relay with the button is a fuel cut off switch, not all mk 4s have them i dont think mine hasnt. Id go with what these guys are saying with the relay. silly question but have you listened to hear if the pump is priming? any number of things can stop a car from starting may not be fuel related if its priming. Quote Link to comment Share on other sites More sharing options...
Guest murcus Posted September 7, 2009 Share Posted September 7, 2009 the relay with the button is a fuel cut off switch, not all mk 4s have them i dont think mine hasnt. Id go with what these guys are saying with the relay. silly question but have you listened to hear if the pump is priming? any number of things can stop a car from starting may not be fuel related if its priming. as above, could be the pink relay ( the same as mk2 golfs) but, you wont know untill you try the pump, it could be that, it could be bad earth, run a live feed from battery to the pump, and see if it goes on? Quote Link to comment Share on other sites More sharing options...
Guest shaun Posted September 30, 2009 Share Posted September 30, 2009 Only the E.F.I had the fuel cut off in the boot. Have you turned ignition on with the lights on and does the pump buzz. Also try the fuse in the fuse box sounds silly but have seen this before.Have known a pump to do this be fine then not work had it on mk 5 cab washed it and it would not start.but could be pink relay as stated by a few that they melt mine loves them (mk4 cab mfi). Hope this helps Quote Link to comment Share on other sites More sharing options...
