Guest Kristian Posted August 28, 2009 Share Posted August 28, 2009 Hi Guy's and Girls, I am looking for some advice! I have a M-Reg (95) Escort 1.8 Si convertible. I brought it off my dad because he had upgraded to a newer car. He had left it sitting for a couple of months before I managed to get my hands on it. The first few weeks I kept Starting it and seemed fine however I went on Holiday for a couple of weeks and when I can back and tried to start it, it wouldn't turn over. The Lights come on the dash but not even the sound of the fuel pump engaging happens and it does not turn over. I Then Got a friend to bump start me and it fired up fine! So i assumed that it was just the starter motor that had gone! Can anyone give me some advice as to whether they think i am heading in the right direction thinking it is the starter motor? Or anything else I could be checking before I spend out on a new one! Thanks for Your Help Regards Kristian Quote Link to comment Share on other sites More sharing options...
Guest IanA Posted August 28, 2009 Share Posted August 28, 2009 the starter motor? Or anything else I could be checking before I spend out on a new one! Might be worth checking the engine earthing by connecting a jump lead between the battery negative terminal and an engine lifting eye. Does it turn over then??? Starter motors are easy to remove and then check with a set of jump leads. Cheers Ian Quote Link to comment Share on other sites More sharing options...
Guest Kristian Posted August 28, 2009 Share Posted August 28, 2009 Ian, Thanks for your reply! I've just tried what you said "Might be worth checking the engine earthing by connecting a jump lead between the battery negative terminal and an engine lifting eye" and it fired up!!!!! Excellent So what Might this problem be??? Earthing ? How can I locate where the problem may be? Cheers Kris Quote Link to comment Share on other sites More sharing options...
Guest bobatporty Posted August 28, 2009 Share Posted August 28, 2009 check battery connectors are clean and tight then check out the earth strap condition and fittings between the chassis and engine Quote Link to comment Share on other sites More sharing options...
