Guest bobatporty Posted August 27, 2009 Share Posted August 27, 2009 Just bought a MK5 the only real problem is the gearchange, It's a bit of a quessing game which gear your going to end up in (till I get used to it)and when your in gear the gearstick is like a kenwood mixer. Anyone tell me what bushes will need changing, part numbers and where to get them from Quote Link to comment Share on other sites More sharing options...
ianxr3i Posted August 27, 2009 Share Posted August 27, 2009 I have just looked on ford microcat & the part (finis) number for the nylon bushes inside the gear stick are 6172154 & you should be able to get them from fords. Quote Link to comment Share on other sites More sharing options...
Guest bobatporty Posted August 27, 2009 Share Posted August 27, 2009 Cheers for the quick reply pal. Is that all ther is just the one, nothng on the end of the rods. I havn't even picked the car up yet (ebay buy) let alone got a haynes yet, so am just quessing it's like most cars. Quote Link to comment Share on other sites More sharing options...
ianxr3i Posted August 27, 2009 Share Posted August 27, 2009 I have just looked on ford microcat & the part (finis) number for the nylon bushes inside the gear stick are 6172154 & you should be able to get them from fords. There are 2 nylon bushes & 2 springs. If you ask for a gear linkage repair kit Quote Link to comment Share on other sites More sharing options...
Guest bobatporty Posted August 28, 2009 Share Posted August 28, 2009 Cheers Ian. I googled the problem and found rs2000 owners have the same problem and use the same kit you mentioned. Cheers Quote Link to comment Share on other sites More sharing options...
