1.8 Zetec Running Rich !!!
Hi All !!!
I'm having a few probs with the Cab, I was told at CLASSIC FORD after the Rolling Road Session that it was running rich, after disscussing it with my Mechanic he said it could have somthing to do with the fan being perminantly on and its not heating up fully !!!
Its been bridged as the fan switch was faulty, this is getting replaced but I wanted some input !!!
CHARLZY
  • 4 weeks later...
Guest EssexRich
Ignore the fact that the fan is on constantly, it's the thermostat that decides whether to send the water through the radiator or not. Check you have the correct stat in the engine. When the fail, the are designed to fail in the open position hence allowing all water through to the rad.
Hope this helps,
rich
so was the problem the afm, because it was cold, and the cold start sensor adding more fuel, so the ecu would have detected that it was cold enabling more fuel causing overfuelling,
was it throwing out black smoke?
Problem was filxed like I mentioned above, it was not overfuling it was running rich, no black smoke just crap MPG's and lower end torque, all sorted now, runs nice and pulls nice !!! :wink:
That was until I was playing with one of my mates MG-F 1.8vvc and my other mates ROVER 600 Ti, then I went back to my lowley underpowerd ZETEC PMSL !!! :happy001:
