Guest clacky Posted August 10, 2009 Share Posted August 10, 2009 Hi Does anyone know if you can get a replacement mast for the normal Ford electric aerial. I'm sure i have seen somewhere that you can replace just the mast rather than the whole unit Any help, as always, appreciated Cheers Chris Quote Link to comment Share on other sites More sharing options...
Guest markeyboy Posted August 11, 2009 Share Posted August 11, 2009 you can change the mast, but it is quite tricky, when i did mine i screwed up the aerial, it still went up n down ok but the reception was verry poor, maby a universal electric aerial would be a easier and cheaper alternative, they go pretty cheab on ebay Quote Link to comment Share on other sites More sharing options...
