Guest murcus Posted July 18, 2009 Share Posted July 18, 2009 (edited) just a bit of usefull info i read years ago ive seen some mk5 with some of the std 1600 8v efi anyhow 4 years ago when i had the xr2i, i bought the fse boost valve to adjust the fuel pressure, after i had cam'd the head and chip'd it etc ok so i looked up tuning back then and realised that the standard bosche regulator is adjustable and increses the top end of the 1600 efi when you look at the std fuel pressure regulator, is small and aloy, and has a shiny silver top on it, you can either drill it off, or put it in a vice ans chap the top off, then inside if an allen bolt to adjust the fuel pressure so you can either turn it up which is clockwise , or turn it down for better econemy, because its an n/a engine, i wouldnt worry too much about running lean, or pre detonation, as obvisously if you turned the fuel pressure down for better econemy you arent going to go for a top speed run. Edited July 18, 2009 by murcus Quote Link to comment Share on other sites More sharing options...
Guest murcus Posted July 18, 2009 Share Posted July 18, 2009 (edited) i knew i read up alot of info on the cvh engine to convert to zvh at jim hearne a major builder, shows you in pics how to convert to rs turbo, how to rebuild and mate the zetec bottom end with the cvh engine and also how to fit custom management and more he was annoyed at one point as people were stealing his info and selling it on ebay on discs to buy not very fair as this spoils it for everyone he explains whats needed to put the 1800 and 2.0 bottom end in, ok enough blabing on heres the link, possibly been posted before: http://www.quantums.info/ but also alot on head identity, tuning etc at http://www.pumaracing.co.uk/CVH.htm Edited July 18, 2009 by murcus Quote Link to comment Share on other sites More sharing options...
Guest macabrio Posted July 23, 2009 Share Posted July 23, 2009 BTW when you adjusted the allen screw did you notice any change in engine note at idle ? I tried adjusting mine to see if it made any difference to my running prob in another thread recently but it did'nt work towards the prob which makes me think my pressure reg is bad. Gonna take it off for some tests later. Also Murcus have you read my last post on my prob askin for a favour if you would be so kind ! Quote Link to comment Share on other sites More sharing options...
Guest Steve Posted July 23, 2009 Share Posted July 23, 2009 Good stuff mate keep the info flowing Quote Link to comment Share on other sites More sharing options...
Guest Ady Posted July 24, 2009 Share Posted July 24, 2009 well done m8 , loads of info there Quote Link to comment Share on other sites More sharing options...
Guest murcus Posted July 24, 2009 Share Posted July 24, 2009 i cant remember if it adjusted the idling or not, the only way i would know, is to get a hold of my mate that i sold my xr2i to, and aski hit to turn it up and down you would think if you adjusted the fuel pressure that it would adjust the idling but i have a funny feeling that the idle contol valve would stop it, Quote Link to comment Share on other sites More sharing options...
