Guest magic rat Posted July 13, 2009 Share Posted July 13, 2009 I've got a leak on the gearbox of my 5b (looks like a drive shaft seal). It'll be the weekend before I get a chance to have a look and in the meantime I want to top up the oil. I've been told that the B5/iB5 uses a different fluid to the MTX but I'm not sure which box I have. Is there an easy way to identify the different boxes? Its a 95 1.8 Si on an M plate. TIA Quote Link to comment Share on other sites More sharing options...
Guest magic rat Posted July 14, 2009 Share Posted July 14, 2009 Right, apparently its an MTX box because it has lift up reverse and a front mounted starter. Does this sound right? I thought all the 1.8's had lift reverse. :msg3: Quote Link to comment Share on other sites More sharing options...
Guest Ady Posted July 15, 2009 Share Posted July 15, 2009 Right, apparently its an MTX box because it has lift up reverse and a front mounted starter. Does this sound right? I thought all the 1.8's had lift reverse. :msg3: mt75? Quote Link to comment Share on other sites More sharing options...
Guest magic rat Posted July 15, 2009 Share Posted July 15, 2009 MTX75 MT75 is the rwd version I think? I found some info here Quote Link to comment Share on other sites More sharing options...
Guest Ady Posted July 15, 2009 Share Posted July 15, 2009 MTX75 MT75 is the rwd version I think? I found some info here same as the mondeo, cant get on that link to look, non member Quote Link to comment Share on other sites More sharing options...
Guest magic rat Posted July 15, 2009 Share Posted July 15, 2009 My friendly neighbourhood Ford dealer has confirmed it is an MTX75. He also wants 14 quid for a litre of fluid Quote Link to comment Share on other sites More sharing options...
