Guest markfrst Posted June 28, 2009 Share Posted June 28, 2009 hi not long had my cabby but have a few issus im hoping somone can shed some light on firstly when the 15a fuse for the interior lights and clock is connected the red light on the clock remains on and drains the battry? the interior fan for the car dose not work i cheaked all the fuses and cheaked the fan the fuse was ok but the fan knackred replaced with a new item still does not work any help would be muce appreachated Quote Link to comment Share on other sites More sharing options...
Guest warlord Posted July 2, 2009 Share Posted July 2, 2009 hi not long had my cabby but have a few issus im hoping somone can shed some light on firstly when the 15a fuse for the interior lights and clock is connected the red light on the clock remains on and drains the battry? the interior fan for the car dose not work i cheaked all the fuses and cheaked the fan the fuse was ok but the fan knackred replaced with a new item still does not work any help would be muce appreachated what year is your cabby m8 i had similar issues on the mk6 and it turned out to be the live feed to the fuse box which i believe is controlled by an inline fuse relay i don't know which one controls the alarm m8 you'll have to get a manual to check it or ask for a relay print out for your model on the internet hope this helps m8 and hope your ecu isn't knackered Quote Link to comment Share on other sites More sharing options...
Guest warlord Posted July 2, 2009 Share Posted July 2, 2009 have you tried unplugging the alarm to see if thats the prob? just a thought m8 Quote Link to comment Share on other sites More sharing options...
